Blown
Engineer
I was down in the basement the other day and noticed that the copper hot water manifold has a ton of corrosion on it, and a tiny drip at the bottom. Perhaps one drop an hour. Everything above a certain point on the mainfold is not corroded, so I should be able to find the leak.
Is this repairable, or should I just replace the whole thing?
If I need to replace it, should I try to reuse the copper valves that are sweated onto the manifold?
Edit: Crap, this looks like the one I have, and it's over $200.
http://www.pexsupply.com/Wirsbo-Upo...d-w-LF-Brass-1-2-ProPEX-Ball-Valve-10-Outlets
