DIYMom2
05-10-2010, 03:15 PM
Hi Terry,
I just bought a new Toto Aquia II but am having trouble with the installation directions. on pg.1 it says I need a 11/32 inch bit to install on a cmt/tile floor (which I have). then on page two it says to drill 5/16 inch holes and use the provided plastic anchors on cmt/tile floors. so--
question 1, do you know what size bit I should be using and if I'm installing on a tile floor do I really need the plastic anchors?
the second unclear part is using the plastic piece called the socket that sits over the septic drain hole. does the wax ring really go under the socket, this seems to be what the picture is showing but how can that get a tight seal if the wax isn't smooshed up against the bottom of the toilet. If I install it as the picture shows then the rubber gasket of the socket would be next to the outlet on the toilet and the wax would be under that. this is different that any other toilet I have installed and just want to get it right. I would truly appreciate your advice. I did look at your sons installation information but it did not cover these items.
Thanks
http://www.terrylove.com/wc/toto/aquia_adapter.jpg
Thanks
