If you're talking about running the hot from the tankless through the small electric heater, you will get some hot water at first but you'll get a cold water sandwich as the electric heater is refilled with the cold water in the pipes before the tankless' hot water gets there. You can run a circulating system with the tankless. Also, you can put the master bath on it's own independant water heater.
