View Full Version : Solar Hot tub
Scuba_Dave
05-02-2010, 04:53 PM
I picked up (2) 4x12' HW panels in December
I was undecided as to how to use them...partially heat house/Sping & Fall, garage, basement ?
Or set them up to provide HW for the house
Well yesterday I decided to set one up & test it out
I connected a small 350gph pump & set it up to circulate the water in my hot tub
Approx 7 degree rise with the panel 1/3 shaded - late in the day about 3:30p
So today I decided I would set the 2nd one up
The 1st one was working & raised the 450g in the hot tub ~7 degrees in 2 hours
It was about 12:30 by the time I had the 2nd one connected & turned the pump on
Initial water coming out (due to shut off) was 140
After running for a while that dropped to 94/7 due to partial cloudy day
At times with more cloudes it dropped to 82/7
Over the entire 6 hour period (10a-4p) it raised the Temp just over 19 degrees to ~75.6
Not bad...2 possible cloudy days coming up then some sunny days
So hopefully by the of tomorrow it should be over 80...nice for a warm dip
I was hooking it up today & my son wanted to go in
Hot tub to him means hot...I had him feel the water - it was only 60 with the 1st panel running
Now I just need enough panels to heat the pool & HW for the house
Scuba_Dave
05-04-2010, 08:39 AM
Into the 2nd day of heating, tub is closing in on 90
Panel output is just over 112
Not bad results for $20 in parts
This will probably save $20-30 a month in electric cost
I will probably disconnect 1 panel in the summer & use that to preheat water going to the WH
I need to build a system to heat water now
7F is a very low delta-T, indicating that you have 3-4x as much pump as you need. Most systems run higher delta-Ts, balancing a slighly lower collection efficiency against power costs for driving the pump.
Hopefully the pump your using is oxygenated-water tolerant. Iron pumps won't last very long in unpressurized open systems like that.
Scuba_Dave
05-07-2010, 06:39 PM
1st pump was not moving that much water
New pump moves more water & in full sunshine can raise the temp 12 degrees an hour
In the morning with low sun I am getting only 3-5 degrees an hour
And in cloudey weather also low output which is expected
Now that the tub is at temp it doesn't take much to keep it over 100
leejosepho
05-08-2010, 06:23 AM
Having just moved to Louisiana, I plan to do the same kind of thing for my 1000-gallon pool and to warm the supply for the water heater for the house.
I suspect thermostatic control of flow would be best. A car has a thermostat to keep the water in the radiator long enough to cool, and now we need to keep it there for long enough to get it hot.
Scuba_Dave
05-11-2010, 07:56 PM
Not a problem keeping the water in the solar heater long enough to heat up
I am seeing over a 26 degree difference between input temp & output
And its still Spring & only 50 out at times
I think I'd misread your earlier post- a 26F delta-T is a quite reasonable operating point. (Somehow I'd inferred "Approx 7 degree rise with the panel..." to mean a 7F delta-T for input/output numbers when you were actually talking about the increase in tub temp over time.)
Scuba_Dave
05-12-2010, 01:55 PM
It was actually both, poor explanation on my part as I jumped from one to the other
With one panel connected & 1/3 of the panel shaded late in the day I was only getting a 7 degree increase from input to output
Then the 2nd day in full sunshine 1 panel raised the entire tub temp 7 degrees in 2 hours
After that the 2nd panel was connected & I saw a much larger increase in the delta T
With clouds I do see it dip down to 5-7 degree delta T for brief periods
But with a sunny day it really cranks out the heat
Scuba_Dave
05-15-2010, 04:25 PM
Working great, shut it down @1pm as the hot tub reached 106 - fully circulated tub water
Also recd the electric bill - lowest in 4 years !!
35% lower then last month, and also 35% lower then same month last year
Now I need to setup a loop to preheat water for the house
Scuba_Dave
05-20-2010, 08:54 PM
I just picked up 4 more collectors - 3x6 but better quality
These are higher quality then the ones I have, but only 3x6
Much better glazing & heavy duty....they look nice
So I'm going to take one 4x12 off the current hot tub setup & add a 3x6
Then take the 2nd 4x12 & another 3x6 & connect them to the hot tub by the pool
Then the last (2) 3x6's for HW for the house
The hot tub by the pool I will also circulate water to the pool to keep the hot tub below ~101
And this will help heat the pool too
Scuba_Dave
05-24-2010, 10:05 AM
The 1st hot tub works good...TOO good !!
It heats up from 96 to 106+ in 2 hours
So I am pulling one 4x12 panel off & adding that to the hot tub by the pool
I've cleaned the tub out & connected the hose to the panel
Input 55, output 78-86 depending upon the sun/clouds
I'll be able to cycle water from the pool to cool it off if it gets too hot
This will help heat the pool too
Scuba_Dave
06-02-2010, 05:51 PM
1st tub is still Maxing out around 106-108, cools down to 104 when I go in at night
2nd tub is only getting up to 98 or so, with the solar panel on the pool cabana roof there isn't as much flow from the pump
But its the perfect Temp to go in with my son
The pool was up to 76 on Memorial Day
Today the surface was up to 82, have to see what it is tomorrow w/filter & pump going
Maybe I can get the last 2 solar panels connected for the pool
Scuba_Dave
07-28-2010, 08:16 PM
I'm actually only running the solar heater on the hot tub every other day now
The warm tub runs every day - It was about 102 today - if it gets too hot I cycle water to the pool
The inground pool - ~19,000g - topped out at 88 degrees during a hot spell
It has cooled off to just over 84 degrees now...perfect
We are using the poool more this year then any other year
I'm extending the roof from the pool caban over the bar area
Once that is done I am adding 2 more 2x20' solar panels ot the cabana roof for the pool
