L84toff
04-29-2010, 12:24 PM
Hey folks,
When I went to start our sprinkler system this spring, I discovered that both our sprinkler heads on the same zone are leaking. I find it very strange that both would have a leaking problem all of a sudden at the same time. We had the system blown out last fall.
We have been doing some landscaping and although we've been careful not to step on either of them, it's possible someone did.
We've been in the house about a year and a half but had no problems with the opening or running of it last year.
The leak itself is at the top, appears to be coming from where the water normally comes out from when it's running. The head does not appear to be all the way down as I can press it down and the leak stops, at least for a moment or two. I've unscrewed the top part and hosed it all off, thinking there may be some debris stuck in it. But after replacing it, the leak continues.
I was going to replace the heads with new ones, but like I said, it seems strange that both heads in the same zone have gone at the same time.
Any suggestions would be greatly appreciated.
