Need to remove drain baskedt that crossbars are broken off
wolf
texas
I need to replace a drain basket in my bathtub that has a lot of corrosion. The stopper no longer maintains a tight seal therefore the tub will not hold water. The crossbars are broken off, so it looks like the standard basket wrench I've heard about will not work. I am very hesitant to cut it out because I would probably do more damage than if I left it alone. Please help. Thanks for any advice.
Nate R
Milwaukee, WI
I have the same situation at my mother's house. Her 20 year old drain basket crossbars broke. Not much corrision at all, though.
So, do we have to cut, and that's the only real option?
Would you tackle this w/ no access to the drain from underneath, or is it more than likely I will require access? (It's a 20 year old Kohler Villager w/ what I believe is a Kohler drain, so I'm thinking I can likely get the same basket)
Esquire
Newfoundland
carefully cut a slit with a hacksaw blade. Careful not to cut the tub itself. Then use a chissel and hammer and use that to unscrew the drain. That's what I did last week.
