View Full Version : Rear Outlet Toilets Kohler Barrington or Caroma Sydney Smart Back Outlet Round Front
paulyjsob
04-16-2010, 08:56 AM
I'm going to be installing a rear outlet toilet in my basement shortly. It'll discharge horizontally after a 90 degree bend into the sewer outlet in the foundation wall. The distance from the 90 degree bend to the wall is about 20" and the pipe has the proper slope. The pipe is 4" PVC by the outlet and goes to a 3" PVC "T" at the toilet flange.
I bought a Kohler Barrington (http://www.us.kohler.com/onlinecatalog/detail.jsp?item=13186402§ion=2&category=20&subcategory=22)a 2 weeks ago but I'm now contemplating returning it and buying a Caroma Sydney rear outlet. The main reason is that its a little shorter and the more important reason is that I haven't read much on the quality of the Kohler whereas the Caroma seems to get to reviews here.
What do you all think?
Paul
Kohler Barrington below with Flushmate.
04-16-2010, 03:16 PM
I don't think there is any difference in quality between Caroma and Kohler.
They have about the same amount of problems for me.
The Barrington is a floor mount rear outlet bowl.
Flushmate pressure assist
The Caroma has a wall mounted bowl with an in-wall tank.
They will install and look very different.
paulyjsob
04-16-2010, 05:12 PM
Hi Terry. Thanks for the reply. I love your site BTW. EXTREMELY helpful!
I think you're thinking of a different Caroma toilet. The one I'm interested in is also a floor mount. And the tank is not in wall..
http://www.caromausa.com/products/index/cu_products72.php
Thanks again!
13146
04-16-2010, 05:54 PM
That is a new model.
So, it has some sort of tube that connects the back of the bowl to the wall flange?
Sydney Smart Back Outlet (http://www.caromausa.com/products/index/cu_products72.php)
http://www.caromausa.com/database/files/Sydney_Smart_Rear_Outlet_US_install_instructions_S ept_2010.pdf
http://www.terrylove.com/forums/attachment.php?attachmentid=13145&d=1306702983
Alan Muller
04-18-2010, 03:16 PM
This Caroma is a European-style rear-outlet toilet. The outlet is 7 1/4 inches (centerline) above floor and connects with a rubber compression-coupling thingy. Quite different from a US style rear-outlet bowl.
Seems potentially very useful for a situation where a stack is accessible but installing a floor flange would be a big project.
paulyjsob
04-18-2010, 05:58 PM
Well. I bought the Caroma and will be returning the Kohler. The Caroma won because its smaller and cheaper. I'll be sure to report back when intalled.
haricot
04-05-2011, 11:37 AM
Could you post where you bought the Caroma and what you paid for it? I'm also curious to know about the material that angled fitting is made out of. Is it plastic? Do you see it once the toilet is installed?
