Next Step - Toilet Plumbing
jeffvdm
Ottawa Canada
Hi folks,
I've got a bathroom remodel underway, have it stripped down to the studs and subfloor.
My next step is to deal with the toilet plumbing. When the old toilet was removed, the flange snapped, so I'm going to replace it with a new one, which isn't entirely bad, since now I can get the flange on top of the finished floor. I can cut away subfloor, so I have to access needed. Existing plumbing is 3" ABS.
I went to my local HD to get the supplies needed and these were the two options I was given, one option leaving my flange to high above my finished floor (I've figured out how high the new floor is going to be) and the second option leaves the flange below the finished floor:
1) Put in a new standard 90 degree elbow, add a small piece of 3" to connect the new flange.
2) Put in a new street 90 degree elbow which the new flange can be directly attached.
Is there another option? Am I just limited at HD because of the standard sizes of parts they have available?
Thanks in advance.
Or you can get a 4x3 street closet 90, and a 4" closet flange.
It's longer, and you can cut it way shorter.
Normall, I can replace an existing ABS 90 and flange with standard fittings.
If that isn't working, then the fitting above breaks all the rules.
Thanks again Terry. I stopped by another supply store and they had an elongated 3" street 90 degree elbow that will actually do the trick.
I did like the 4x3 idea better, but they didn't have any.
