Toilet bolt
Peterl
cal
What do you guys do if the bolt is long that the cap is just hanging on the bolt as oppose to the cap being snug? Thanks
We cut the bolt shorter after the nut has been tightened down.
what do you guys use to cut the bolts? Thank You
I don't want to sound really dumb but I am thinking a dremel or bolt cutter. Just curious what you guys in the industry use?
Hacksaw. A dremmel with a cutoff blade would work, too. You can also buy segmented, break-off bolts that you grab with a pair of pliers after tight and break off the excess at one of the notches. Not worth it to reset the toilet now, but maybe next time. If you cut the bolt before you put the nut on, you may not get the nut on! You can get it off later because the nut acts like a thread chase and straightens out the bent threads you made by cutting it off.
IF you use a bolt cutter, you will need it again when you have to remove the toilet. A Dremel tool also will create a burr which could cause you a problem if the bolt is not secured to the flange. I use a mini-hacksaw which gives a guick smooth cut.
