Can someone double check my wiring diagram?
dizzo72
seatte
Does this seem like a reasonable way to get four fixtures in a long journey without running 3wire the whole length?
Reasonable is a relative term.
I never run the travelers thru the lights. Too many extra splices and you have to take fixtures down to troubleshoot.
2 wire power at one end, 2 wire switch leg at either end and 3 wire between them is the way to go. Nothing in the fixture boxes except the switch legs.
Eliminate the run you call #1, and run a two wire, (not 3 wire), cable between the two switches connected to the "traveler" terminals. You have the neutral taken care of in the boxes, so all you need is a "hot" to the first switch from the "fixture #1 box", the travelers between the switches, and the "load" wire from switch #2 to the "fixture #4 box". This will simplify your wiring in the boxes.
Unorthodox wiring methods rarely simplify anything.
Keep the power and switch legs in the switch boxes and run a 3wire between them.
