View Full Version : Sprinkler zone turns on automatically
pansenbaer
04-10-2010, 01:10 PM
Hello all. I just turned on my water today to my sprinkler system to be met with an odd surprise. As soon as I turn the valve from the back flow assembly to the sprinkler line, one of my zones fires up and I have no way of controlling it other than to turn the valve back off. I can flip my sensor switch on the wall unit to bypass and test the other zones, but I can't get this one zone to shut off. Any ideas? Thanks.
Nate
Fireguy97
04-11-2010, 12:46 AM
You could have either a bad solinoid, a stuck solinoid, or whoever winterized your system open the valves manually (by turning the solinoid) and left that one open.
Mick
Most valves WILL operate when the water is first turned on because they have lost their pressurization, but they turn off as soon as the valve chamber fills with water. You either have a damaged diaphragm, bad solenoid valve, or the manual control is turned on.
