View Full Version : Crimped Supply Lines
DMLane
09-14-2005, 02:39 PM
I hired a plumber to install two bathroom sinks and faucets. I requested metal traps and hardware since these elements are exposed and not hidden inside cabinetry. Upon inspection, I noticed that the supply lines (chrome plated copper?) were considerably crimped during installation in order to coax the line into the proper position for hookup. Two of the lines have about an 85° angle and the chrome plating is now abraded. The water flow through the tap seems strong enough, but I worry about the integrity of the supply tubes being compromised and weakened at the bend. Is this a valid concern? Should I request that the plumber return to redo this work?
Thanks in advance for your replies.
DMLane
plumber1
09-14-2005, 03:31 PM
replace for sure..........
Are they actually "indented" crimped, or merely a gentle curve? A sharp bend will eventually crack at that point.
DMLane
09-14-2005, 06:56 PM
Hi hj. It's a very sharp bend with a crease and a flare-out of the metal. The chrome plating is also chipping off at the site. Should I request that he install braided stainless steel risers instead? What is the best material for this component? Thanks in advance for your help, hj.
DMLane
The problem most people have with the braided supplies on a pedestal lav is that they are a fixed length, and so they have to be looped or twisted to use up the extra length. There are some made with a section of copper tubing that can be cut off and eliminate that problem, but they are not a normal stock item with most suppliers. He should use a tubing bender if he is going to install the chrome risers.
toolaholic
09-14-2005, 09:32 PM
i question, weather the person that left this, has it in them to do a proper job! hire for attitude, train for skill, is how i work. there isn,t much of that anymore! sorry i,m rambling again. good luck
DMLane
09-14-2005, 10:06 PM
Thanks for the explanation, hj. I'm not too keen on looping or twisting, so I'll be prepared to inquire first about length. Your replies have been a big help.
DMLane
DMLane
09-14-2005, 10:09 PM
Hi toolaholic. Yes, I question his commitment to quality at this point also. You are so right to hire for attitude, for that cannot be taught. Thanks for your reply.
DMLane
DMLane
09-14-2005, 10:12 PM
Hi plumber1. Thanks for your reply. They will be replaced tomorrow. :)
