Need help on installing Oatey drain in new fiberglass shower stall
Georgie
Hingham, MA
I am in the process of installing a new fiberglass shower stall in my bathroom. Up to this point everything is fine...however, I am a bit confused on how to installed the drain. I hava Lasco shower stall 60"x 36" the drain is in the center of the shower. The shower stall is big with little room on the adjacent walls for movement. I am using a Oatey plastic drain connector...question number 0ne? How far should the 2"pvc stick up from the floor for final installation? Question 2 how do I get the big and awkard to move shower stall over the rough in pvc? Question 3 is their a solution I use to put on the Oatey drain so it helps to slide over the pvc pipe? Any other insights would be appreciated?
All the best,
Georgie
