View Full Version : Low angle nozzles
teamo
09-12-2005, 07:38 AM
I have Hunter PGP rotary heads on my system. I have the regular red nozzles installed that came with the heads. I have seen low angle nozzles (gray) advertised in the literature that came with the heads. What is the advantage of using these? I can only guess that the spray will stay closer to the ground with less of an arc, but when would it be appropriate to use these?
Thanks Jim
PEW
09-12-2005, 08:30 AM
Will allow reach under low branches.
jimbo
09-12-2005, 08:36 AM
They are used mostly in areas where heavy winds cause havoc with the spray. A lower angle will have somewhat less distance, but will also be dispersed less by the wind.
