Smoke alarms: what brand should I buy?
BurleyMike
SE Idaho
I have needed to install smoke alarms for a while now and I figure it is better to spend the time in the attic running the wire while it is still cool up there.
Now I am trying to decide on what brand and model to buy. I have been looking at the Gentex 120v and Kiddie 120v, tandem operation, battery backup.
The Gentex cost quite a bit more than the Kiddie units. Is there a good reason for this? I noticed the Gentex is made in the USA which is a plus to me. Any alarm experts that can tell me which would be a better alarm?
I don't want units that will go off every time I put some wood in the stove or the wife burns some toast.
From everything I have read photoelectric is supposed to be better for smoldering fires and less false alarms?
In theory, there is no difference between brands, but take a chinese import for what it is.
Yes, of the two types ( ionization and photoelectric) the photoelectric is less sensitive to false alarms from burning toast in the toaster, etc. In general, they recommend not putting smoke alarms close to kitchens or steamy showers, but if you must, use the photo. If you are going to interconnect alarms, it is preferable that they all are the same brand, because no one will give you assurance that their model interconnects properly with another brand.
I couldn't tell you what brand is better as I've never seen a Gentex, but Kidde is pretty well known. As for types, you want both or combination units as they both operate differently, detecting different fires at different rates. Photoelectric are generally considered better for preventing nuisance alarms, but I wouldn't give up the ability to detect a flaming fire or one with fine smoke. If it were me, I'd put photoelectric in all living, sleeping, and common areas, with an ionization or combination unit in each of the common areas as well.
Consumer Reports has done extensive testing on multiple different types. They HIGHLY recommend buying a unit that is both a smoke and CO2 detector. The cheapest highly rated model is a First Alert CO615.
Actually there is good product in the market like Gentex 120v and Kiddie 120v, tandem operation, battery backup,you can try out that.
