Toto Carusoe tank leak
Daddio
ca
My toto is leaking at the same place - down the big threads of the flush valve base.
Is the thin rubber gasket and the big nut on the valve base supposed to make it watertight alone? If so, just snug the nut? Or would plumbers putty help?
Or, does the tank-to-bowl donut really seal the threads?
Thanks I checked the porcelain and reinstalled, but there is still a very slight drip down the threads when I set it out to test it. This is a fluidmaster 2" valve and gasket on a two-year old Toto Carusoe. The porcelain is clean, no crackis.
Is there a better gasket to try?
