View Full Version : No soft water after filter change on a Kinetico
Tony Foran
02-24-2010, 02:55 PM
I swapped out the pre filter and now I'm only getting water if the softener is by-passed. Do I have air in the system? What I'm I missing?
Thanks for any help,Tony
Skip Wolverton
02-24-2010, 03:13 PM
There is a plastic rocker inside the valve that, if broken, will not allow water thru the unit. I have a picture of it but don't know how to post it.
Tony Foran
02-24-2010, 03:26 PM
It worked fine before the filter change but now I only have water on by-pass. I could have damaged the valve somehow?
Akpsdvan
02-24-2010, 04:58 PM
What kind of bypass for the kinetico?
Did you bleed the air out of the pre filter after the filter change?
Peter Griffin
02-24-2010, 05:08 PM
Skippy, you have to go advanced so you have all the posting options. There is a thing looks like a paper clip, that's for attaching photo's.
Akpsdvan
02-24-2010, 05:10 PM
Is that plastic part that easy to break?
Is it one of them that if you look at it wrong it breaks?
Tony Foran
02-24-2010, 05:14 PM
No, I did not.
Tony Foran
02-24-2010, 05:17 PM
That did it! Thanks a lot for the help.
Akpsdvan
02-24-2010, 05:26 PM
If this was in Alaska I would be saying
Strange things happen in the land of the midnight sun.
Why a ball valve is not used before and after a pre-filter is still a strange thing to me.
Skip Wolverton
02-25-2010, 10:02 AM
Yes the plastic rocker can break at anytime. When broken, it causes both pistons to close shutting off the water supply. The rocker is the ones in the upper right side of the pic (small piece). Thanks for the help.
Akpsdvan
02-25-2010, 11:06 AM
Brake at ANY time?
Och....
Is it a fail safe idea?
Why would some thing that could cause that much trouble still be in use?
Skip Wolverton
02-25-2010, 12:48 PM
Brake at ANY time?
Och....
IIRC when it switches tank, the rocker forces the opposit piston to close preventing water flow from the tank in regen. They do break easily with age.
Akpsdvan
02-25-2010, 12:51 PM
Every unit has its weak point..
