Is one way better than the other way
DIY
Florida
Would either of these setups make a difference in water flow/delivery time?
3/4" piping that goes into 1/2" piping?
1/2" piping that goes into 3/4" piping?
Winslow
Hawaii
Depends on the demand on the line and how long the 1/2 line is. Increasing the diameter of pipe will only reduce friction loss.
Water pipe sizing
DIY
Florida
Kitchen sink with swivel handle hot/cold faucet.tub/shower Hot / diverter valve / Cold , Toilet , lavatory sink Hot / Cold. The 1/2" hot side line would take a few turns,but it will be 20' in total length. From the water heater exists @ 1 1/2 to 2' of 3/4" piping.
Jimbo
San Diego, CA
Increasing pipe size will minimize any further friction PSI loss based on GPM flow. Decreasing the pipe size will increase friction loss at a given GPM
Cacher_Chick
Test, Don't Guess!
Don't overlook that by running 3/4" you will need to move a lot more water waiting for the HOT to arrive from the water heater.
DIY
Florida
Thank you all,Winslow,jimbo and cacher_chick
So, if 3/4" piping is used for all 20' of hot line there will be better water volume. If 1/2" piping is used for all 20' of the hot line it creates a bit less volume,but more pressure.Ok. I can live with less volume,for more pressure if that gets the hot water to any 1 of these fixtures at a time.( kitchen sink,tub/shower,lavatory sink) in a reasonable turn of the handle on,or under a few seconds?
Volume is a function of pressure. A long 1/2" line will reduce BOTH volume and pressure. A 3/4 line has less pressure loss so it will give more volume. The hot water will get to the faucet sooner because a 1/2" line holds about 1/2 the amount a 3/4 line does so you have to evacuate less cooled water. All the dynamics are interrelated so you have to decide which parameter is more important to you.
Jimbo
San Diego, CA
20' is a pretty short piece of pipe, and you would not likely notice the pressure difference, or the time to get hot water, either way.
DIY
Florida
Hi all,
I do not want to beat this post into the ground,but future plans for this place make it important. Hj the parameters that would be important to me would be hot water that one would not have to wait for at the faucet that would waste less than a half gallon, half gallon or more of water for,no need for a reckrculation pump (i think this short 20run of piping can be solved via the right size pipe..? There is always just testing to see the difference the two pipe sizes would make....hmmm cpvc too...
Thanks to all and the plumbers & master plumbers!
DIY
Florida
I know volumes and pressures can be pretty amazing depending on the space they have to travel through,but the difference here seems pretty min ute to me? Maybe that is a drastic change to effect the flow and/or pressure?
The copper and CPVC I have here measures the following ID:
1/2" copper piping type "L" is just shy of 9/16"
1/2" CPVC piping type "Flowguard Gold" is right at 1/2"
