View Full Version : Dryer vent/ducting
DIY
02-21-2010, 12:28 PM
Hi all,
Does anybody here have any first hand experience with periscope type duct that is square in shape,and measures 2" x 6" for limited space installations, and is said to work as well as the standard 4" round duct?
Thanks to all!
jimbo
02-21-2010, 02:27 PM
ALthough they are a little flimsy, they seem to work ok. I have not seen any actual test results about air flow. Be sure to tape all joints with foil tape, or you will "leak" lint.
Gary Swart
02-21-2010, 08:04 PM
The only ducting I am aware of the should be avoided is the flexible tubing. That's because the ridges inside catch lint and eventually create a fire hazard.
asktom
02-22-2010, 09:48 AM
We have sold them for years with never a problem. Do tape the joints.
Master Brian
03-02-2010, 10:50 AM
Does that hold true if I use about 4' of the flexible aluminum(?) stuff to make a connection to rigid dryer tubing. It was used to simply a sort of complex bend and make connection to the dryer easier. Most of it will eventually be buried behind a finished wall, I'm guessing it should be replaced with rigid pipe. Sorry for the intrusion...
