rockycmt
02-16-2010, 08:17 AM
I have a very tight log home in the mountains of Upstate NY. When I light a fire it seems to draft well. Once it dies down the slightest wind outside overpowers the smoldering abbers and causes a backflow of smoke and soot into the house. Opening a window makes it even worse. What are my options?
Add 5 feet to the stack to give it better draft, and top it with either a venturi-type or whirlybird-type wind turbine so that even the slightest wind gives it a stronger draw instead of a backdraft. These people (http://www.empirevent.com/) have a decent selection of vent turbines, etc., but they have plenty of other competition (http://www.volko.com/turbine.htm). If you're going for a whirlybird sure to pick an all-metal version (some have plastic bearings) if it's to be used on a chimney.
If it's next to a gas or propane flue in the same chimney you need to go stainless or it'll corrode quickly, otherwise copper or galvanized both work for wood-fires only.
I prefer lower-performance but lower maintenance venturi types myself. Too much suck and you de-pressurize the house, increasing outside air infiltration. Something that looks like these is usually enough to make a difference, along with a few feet of extra stack:
http://www.bbsheetmetal.com/images/products/531/p531.jpg http://www.bbsheetmetal.com/images/products/535/p535.jpg
