You need a good pipe wrench with a 30-40" pipe slid over the handle for leverage. It will come out.
Also, when you are using heat, heat the outer threaded fitting, not the inner one. The heat makes the metal expand and heating the inside plug only makes it tighter.
When dealing with bigger fittings like that a propane torch is not likely to make enough heat.
