Tarheel Technician
Came home and heard the pressure tank cycling on and off continuously under the house. So I turned off the breaker to the well pump......opened the closest faucet to drain the tank......and the pressure gauge slowly decreased to almost zero. Put a tire gauge on the valve stem on top of the tank and it was also close to zero. I'm assuming the bladder has ruptured. My water has a brownish color to it now.....which I'm assuming is coming from the ruptured bladder.
Also.....after cutting the power to the well pump.......the pressure slowly drops to almost zero even without turning on any faucets.
Am I correct in thinking the bladder has torn.....or is there something else that it could be?
Thanks for any help/advice!
