Pete Crivitz
Terry,
I drove a 2" sandpoint down approximately 20'. Water level is at about 15'. I regret oversizing using 2" pipe now that I am ready to plumb a 1.25" suction Red Lion jet pump.
Question: will the Red Lion 1.25" suction line lift the 2" column of water out of my 2" well aproximately 15' ?
Or should I put a 1.25" pipe down into the 2" well casing?
If I do use 1.25" pipe inside 2" casing, how do I create suction around the 1.25" pipe that is inserted into the 2" casing? I do not see any 'well seals' that are available for a 2" OD pipe. All well seals start at 4 or 5" diameter and larger from what
I can determine.
Thank you very much.
Pete in Green bay / Crivitz WI.
