TSAspinall
My husband and I have been remodeling our bathroom for the past two weeks. We continue to have problems with the plumbing in the tub/shower. When we first started it we changed the copper piping to pex piping using crimper connections. After finding leaks at the income source we changed the connections to sharkbite however (with the exception of the hot on the manifold) everything else is still using crimp connections. We've used the shower once and there was a downpoor leak in the basement but we can't see where it's coming from. With the water on it doesn't leak, with the tub spout on it still doesn't leak, but when we turn the shower on it starts to poor. We thought it was a leak in the wall somewhere so we opened it up around the manifold but it's completely dry. The only sign of water is in the basement around the incoming pipes (not the drain). I have absolutely no idea where the leak could be coming from... any thoughts?
Ps. We have used Delta faucets and have a marble tile surround with cement board and vapour barrier behind it.
