View Full Version : P-trap clearance?
:confused:
I just had our bathroom plumbed to add a sink in our master bath. The cabinet & countertop were installed. I have a question about how to make the plumbing work. On one side, the drain only has 4" below it before it reaches the cabinet. How can we make the p-trap work? Can we add something to give the inch or so we need to get the clearance needed?
If you are describing it the way we are reading it, then the answer is no. The "P" trap cannot be elevated so you may have to cut an opening in the shelf or bottom for the "P" trap to hang into.
jimbo
09-03-2005, 03:59 PM
Are you recycling a piece of furniture into a vanity? It would be unusual for a "regular" vanity cabinet to have such low clearance. You will really have to modify the cabinet to accomodate a trap. Theoretically you could elbow right at the bottom of the sink, go back towards the wall and then insert a trap, but I don't think you will find fittings to do this. Ant this would always tend to be a slow-drainer.
plumber1
09-04-2005, 08:09 AM
See if you can turn the j-bend around. Use a non slip rubber washer on the tail-piece. The washer is like a big fat o-ring and if you try to pull the jam nut off with this washer on the tailpiece, it will take a lot of pull and then it might not slide off.
Keep the tailpiece as long as the space will allow.
It works well and you will not loose the water seal.
toolaholic
09-04-2005, 09:14 AM
are you refering to a mid point shelf or the cabinet bottom?
plumber1
09-05-2005, 10:29 AM
Tool
Thats a good question.
I took him to mean that his new pop-up assembly was set lower than the old one and that he need more room for the tailpiece............
