Our 1965 house has the original cast iron garden type tub in the guest bathroom. We want to put in a regular tub. I've attached a picture showing the current setup. From another plumbing job I believe the main line runs below the wall on the left hand side from front to back, with the septic tank at the back end. All fixtures in the house have a dedicated vent through the roof except for this tub and the shower in the master bath. Does that mean this tub is wet vented?
If so, can I move the drain as proposed? It would be ~18" shorter and need to move several inches to the front of the picture.
Would I use a no hub and then pvc to get to the correct location? That is how the plumbers put in the new pvc trap and riser in the master bath shower when I redid it.
I appreciate the help!
