Cleaner vs primer
Steelers Fan
va
I screwed up the other day redoing a retired union plumbers kitchen sink pipes at least I think. I accidentally grabbed a can of clear PVC cleaner I had on my truck thinking I had grabbed clear primer. I realized it after a couple of joints and switched over to primer. It was getting late so I left it for now but am going back tomorrow to cut those two fittings out and redo them correctly. But I figured I'd ask if you guys if these joints would actually filmi sure they will but at the same time when reading the cans of cleaner and the primer they list the exact same ingredients. Anyone have any input on this? thanks
p.s. brown can and yellow can I must be going color blind
index.php
I wouldn't change it. Primer is similar to cleaner....just more agressive.
Plenty of sprinkler pipe is installed with neither! For DWV, your joints should be fine.
Primer has a dye in it so inspectors can tell it has been used. I agree no problem on DWV.
thanks guys went there today and filled both sinks and let er run no problems Ive just never used cleaner at all before only had it cuz i got a lil sloppy with purple primer.No leaks and got to swap out the old globe valves under his sink too( no angle stops ).So it was a slow day but all good.Thanks for your help
No Problem
I wish I had a dollar for every pvc joint thats holding fine glued with only the cement. Ive been guilty few times myself even on supply pipes when in a tight and had no cleaner or primer . Ive never had a problem with that.
I just left a house the other day where a guy used nothing but glue and before he got there the tub overflow and drain dripped after he left it poured;)
The cleaner/primer not only takes the crud off, but also softens the surface a little so the cement can melt and fuse the pipe into the fitting better. I think it somewhat depends on how much of the solvent has evaporated out of your can (i.e. an almost empty can has probably lost a bunch of the solvent) - when new, probably won't notice much, but you are likely to if at the end.
You don't wan't that 2 AM CALL
i wouldn't change it. Primer is similar to cleaner....just more agressive.
Plenty of sprinkler pipe is installed with neither! For dwv, your joints should be fine.
cut it out , it is not the same
I have seen some so called plumbers mix some primer with the glue to give it the purple color.
John
