clogging problem with dialysis drain
vleespet
My wife is on peritoneal dialysis and the drain is in the bathroom sink.Every month I need to unclog the drain since there is a lot of build up sludge from the dialysis fluid. Is there a way to reolve this problem....for now the drain is in my toilet.
Ron
First you have to figure out what is clogging the drain. then We need to know how you are attempting to unclog the drain. I am suspesting that you are using a plunger or a hand held/manual type snake (if any)
I would suggest a small power drain machine to clear your problem, then when you start re-using the drain for the dialysis drain, run water with the fluids being dumped into the sink.
