Re-routing sink DWR possible??
dirtmcgirt79
Ok, so my wife and I are remodeling a small bathroom on the first floor. We were all set to install a recessed medicine cabinet, so I cut the hole.. Only to find the sink drain pipe from the 2nd floor bathroom vanity running down in the middle of the hole.. I should have figured that was gonna happen.
So anyway.. the pipe is running between 2 2x6 studs.. I have to frame out an opening in the framing anyway.. Is there any chance that i can re-route the drainage line? If I start up high enough in the wall, put in a 45degree elbow and run it out past the hole, then down, and back over so that it'll line up with the 1st floor drain?? This is PVC pipe..
Or should I abandon this project and just hang a mirror instead?
Thanks for the reply Taylor.
I took a few pics at what I'm up against.. I guess the question is, can it be offset this much??
pipe
He said it is the drain from the upstairs sink, and since it is 2", that is probably the case. I am not sure how the lavatory is connected, but if it is into that 2" riser it would be improper under most codes. He can offset it as much as he has to, as long as he does it correctly, using 45's.
The pipe says it is 1.5", so it may be just a dry vent. Go upstairs and turn on the sink and see if you hear water running down that pipe.
I have a similar situation where they wet vented the basement sink through the drain of a pair of lavs on the 2nd floor. I am fixing this along with properly venting the shower and washer connections by running a new vent to the roof (pain, but the only way to do it right in my case).
It might also be helpful to stick the camera in the wall and get a pic of how the plumbing joins together.
Kent
