Help! Cold water Valve to Washing Machine Leaking
m_jhess
The cold water valve to my washing machineis leaking. I have tighten the nut that is in the middle, but that has not helped.Can anyone help? Does this valve need to be replaced or is there something else I can do? Is there somewhere I can go to get instructions on how to replace.
Thank you for your help!
valve
If we knew what kind of valve you are referring to, i.e., one in a box, valves on pipes sticking out of the wall, or valves in the wall with hose connections in a box below them, we might be able to answer the question.
