Electric Water Heater Heat Loop
Earnie
At Home
I have a few questions on heat traps / heat loops.
Are they worth the cost to install?
Which is the better option, mechanical heat trap or passive loop?
I have concerns that the mechanical heat trap will restict water flow. I can not find a 1" heat trap, only 3/4 inch. Would the loop be a better choice since it can be made of 1" pipe.
If a loop is used, is it normally a circular loop of pipe or made with in a square with 90 degree elbows?
Thanks.
