View Full Version : Water Heater Burner Knocks out Pilot...
Waldo_vt
08-31-2005, 06:24 PM
Hello All
Well my gas water heater pilot light will not stay lit and I did a bit of investigating and I think I found the problem but I do not know how to fix it. Apparently when the burner comes on the pilot light goes out. After lighting the pilot I will slowly turn the temperature know up until the burner lights. Then when I turn the temperature know down the burner shuts off but the pilot is out. When lite the pilot flame is a good strong blue with some slight orange hitting the tip of the thermocouple.
What can I do?
Thanks again.
Gary Swart
08-31-2005, 11:05 PM
New thermocoupler.
Waldo_vt
09-01-2005, 03:55 AM
Thanks but I have already replaced the thermocouple.
toolaholic
09-01-2005, 05:12 AM
some gas appliances have a small ajusting screw. look on the regulator out front. also tighten, if necessary the small pilot fitting going in to same control
thezster
09-01-2005, 05:15 AM
Had a similar problem last year - it required replacing the thermocoupler - twice....... first one was defective...
Though it sounds as if the burner lighting up is blowing out the pilot - and it's not re-lighting
master plumber mark
09-01-2005, 05:16 AM
the high limit switch is burnt out in the gas thremostat.
they cannot be repaired ,
and arent meant to be messed with
so you need a whole new gas thermostat
costs about 65 bucks...
what brand of water heater is it???
if you got a whirlpool, it might be trouble...
a small tip
remember to turn water off first before unscrewing valve..
Waldo_vt
09-01-2005, 09:13 AM
Thezster,
Yes you are correct the burner lighting up is blowing out the pilot and it is not re-lighting.
MPM:
Why do you think the high limit switch is burnt out in the gas thremostat? I thought that a burn out high limit switch would keep the burner and pilot from even lighting up? BTW it unit is a very basic 40gallon shorty State Select water heater ~8-9 years old.
Thanks you for the responses
master plumber mark
09-01-2005, 02:45 PM
Again I ask
WHAT BRAND ARE YOU TALKING ABOUT?????????
If the thermocoupling wont work its just the next step..to try...
----barring some exotic vent problem
you see once in a blue moon... or
you could have a bad orfice in the burner assembly,
but usually we only see that kind of problem it the unit
has been under water
you got to just assume its the hermostat that is the problem..
They cant be repaired
so you just got to trust that its the problem....
it cant be anything else, cause their isnt anything
else it can be
we just went down this road today....with a Bradford White unit
changed out a thermocoupling a few weeks ago now its
going out again....sent one of my guys down ther ewith
a thermostat and changed it out....
its all trial and error.. good luck...
Waldo_vt
09-01-2005, 05:23 PM
MPM
The unit is a "State Select" shorty 40 gallon water heater.
Thanks again
master plumber mark
09-01-2005, 06:05 PM
Is the unit a pre-2003 water heater or the new
sealed combustion type.....
with the sparkey push button type
ingniter???.
If it is the newer style with the sealed combustioin feature
you got troubles.....
they are trouble
get the serial number off the unit, it should tell you how old it is
jadnashua
09-01-2005, 07:00 PM
He indicated it was 8-9 years old. It might be more cost effective to replace it...it's on it's last legs in all likelyhood. My unprofessional opinion.
RioHyde
09-02-2005, 02:12 AM
I'm with Jadnashua. Since its 8-9 years old and giving you that much of a headache replace it before it soaks you.
