Couch-Tuber
reading through old threads there are some here who don't think dielectric fittings work. My understanding is that they serve to seperate two dissimilar metals to prevent corrosion caused by a dielectric reaction. I found four types. The copper flex and large nut type seem to be truly dielectric. The two types of nipples seem to still contact the nut at the threads. Why then are they labeled as dielectric?
Same fitting dissassembled
Note where the brass insert goes into the steel nut, there is only about 1/16" air space although the nut should torque down straight so there is no contact unless you managed to put it on crooked or if the plastic insert was crushed
