a few more questions:
-if my bathtub drain pipe is 2" does the p trap off the tub need to be 2" or can it be 1.5". the vent is 1.5" does this matter?
- can a toilet 4" waste pipe have a 90 degree bend in it laying horizontal and if so does it need to be a long sweeping one
- when cutting a wye or T into a cast iron main stack, what fitting is required if the line coming in is ABS 2 or 3". do i need a cast iron fitting?
- does a vent care if it has a 90 degree bend in it versus two 45's
- can i use flexible water supply hoses (typical for sinks) to supply a shower? thinking from the shutoff to the actual shower control so a run of 10" or so - otherwise i have to reroute the existing copper
thanks
thanks
