View Full Version : So you've installed all new copper pipe, then what?
Dave Treen
08-30-2005, 10:35 AM
I'm replacing all of the iron plumbing in my house with copper. Granted, each soldered joint gets wiped down to prevent corrosion, but what about the inside of the system? I've been applying (lead-free) flux to all the joints, but it's hard to ignore the label on the can that says "POISON". Further, I've noticed that solder (lead-free) has puddled inside some of the joints. Should the new plumbing be flushed with something before being put into use? Thanks!
Kristi
08-30-2005, 02:42 PM
It's always a good idea to flush the system after it's been freshly installed. The solder inside is fine, it'll look like a tiny rim sealing the joint, rather than how it looks on the outside. The flux better be lead free! lol... just give it a good flush and you'll be good to go.
Clockman
08-30-2005, 03:07 PM
As Kristi mentioned, simply turn on the water, but take the aerator of the faucets first. :)
Al
A lot of things are "poison". If you made the joints properly with the correct amount of heat the flux would have "burned" off in the process.
Clockman
08-31-2005, 04:32 AM
Not to mention that inside the fitting cup you can't fit a whole lot of paste, so when the solder replaces it through it's capilary action, there isn't much left to worry about. Did I just say not to mention that? :rolleyes: :) *Most* of the paste comes to the outside. ;)
Al
Dave Treen
08-31-2005, 01:22 PM
Thank you all for your replies!
On the surface they did seem like dumb questions, but most of the materials I read made no mention of what to do after the system's hooked up.
SteveW
08-31-2005, 04:22 PM
Not dumb questions at all! I have wondered about this myself. I guess modern fluxes are water soluble, so should be able to be flushed from newly-soldered pipes, but I've never heard a specific recommendation of how much flushing is required. I've certainly been able to smell the familiar scent of flux in the water I've flushed after a repair job, but seems to dissipate quickly.
