Heating formulas
Rocki
Mass
I am installing a new hot water boiler replacing the existing one. Have added more space. Where do i find a calculation sheet to determine boiler size?
You're talking about a heating boiler, right?
What you need to do won't fit on one spreadsheet. You need to do a Manual J load calculation to find the heating needs of your space and then size the boiler as required. Manual J is very involved; the only practical way to do the calculation is with specialized software. HVAC Calc and RHVAC work well.
Even Manual J is just an estimate.
Have you heated your home and additional space through a winter with the existing boiler? If so and if you have a monthly record of utility usage, then you could combine that with daily average temps over the same periods to estimate actual sizing required. The usage over a given time period with given average temperature can be scaled to determine peak usage at the design temps.
