New drain for water softener
Cacher_Chick
Test, Don't Guess!
Rough-in for water softener?
I am planning a basement rough-in that will eventually have a water softener. I'm wondering what common practice is for a drain?
I was thinking of putting in a trapped and vented standpipe identical to one that would normally be used for a washing machine. Is this overkill or would a floor drain be more practical?
I assume you mean the drain for the water softener.
Both of your suggestions will work. What we most commonly see is either floor drains or a connection to the tail piece of the nearest laundry or other sink, above the trap. The tail piece is a plastic pipe with a side Y connection.
Thank you both for responding. I was pretty sure a standpipe would be the best solution for a softener drain, but it's good to hear it from others.
The softener will be at the service entrance where there are no other fixtures so it will need a dedicated drain.
Thanks again!
softener drain
Not always the best idea. If the softener operates often enough to keep the trap filled you will not get any odors, but if you were to shut it down for a period the trap would dry out. A better way is to hang it over the washing machine trap, or insert a Y and 45 into the standpipe with a secondary standpipe for the softener.
