View Full Version : Moentrol spool problem help
master.legend
12-19-2009, 09:05 AM
Any tips on removing the moentrol balancing spool? I've tried a large screwdriver and a flat wide chisel with no luck. Also sprayed with white vinegar? Need to get this out without stripping help??
12-20-2009, 07:38 AM
I have had luck by "drifting" it using a hammer and chisel in the screwdriver slot to get it started. Once you move it even a little bit the large screwdriver will work.
