I am re-doing my upstairs bathroom and have 2 questions.
#1
The drain for the tub is a 10' run to the main stack through the floor cavity only - with a finished ceiling below and no vertical walls to go down, so it is a "low sloping drain" (but is still layed at a 1/4" per foot)
it runs straight for 8' then hangs a 90 degree right and runs 2' to the main stack. It is vented at the tub and at the 90 degree bend (and the main stack as well). The sink is completely separate with its own vent and runs direct to the main stack as does the toilet.
QUESTION
Do I need a 3" or 2" ABS drain pipe for that distance. I initially ran 1.5" but it's draining slow. I see by code it should be a 3" due to the critical distance length between the trap and the vents but since it all has to fit in the floor cavity, the bigger the pipe, the lower the slope as i only have so much space in the cavity between the bathroom floor and the living room ceiling below.
--Can I get away with a 2" one?
#2
The water for the tub, toilet and sink all pull off the same 1/2" copper lines coming up through the wall from the basement (house is from 1950). All the plumbing in my house including the main line in from the city is 1/2" copper
QUESTION
I see by code if more than one fixture is run off a supply line it should be 3/4". If the whole house including the main in is 1/2" is there a point in adding a section of 3/4"? If so how far back do I need to go?
--is there a point in running 3/4 if the main line in is only 1/2" ?
thanks
#1
QUESTION
#2
QUESTION
thanks
