And WHY can't he use a "Y"? There is absolutely no difference between that and a sanitary tee in a vertical line. The question might be why it is being done that way, however.
Here is that another way I was going to route the pipes, but this one involves putting a hole through the floor joists which I was trying to avoid by coming underneath then through an existing soffit. I imagine there are other ways I can accomplish this, so I will keep working at it. However, do I have the same problem with the wye on it's back? I thought this configuration was typical.
Thanks, I think I will try to stay away from the goofy stuff! A washing machine drains above the W/C, and a shower drains above that with a vent coming out the top of the stack.
I figured a different way to route the drain from the W/C & Lavatory, though I will need to make the soffit a little longer than the one that is there now. Everything get a lot more straight forward if I just drill though the floor joists, but I'm just a little nervous about doing that if I can find another way.
