trimming solid surface vanity top
Blank
Philadelphia
I am attempting to replace the vanity and sink in my "small" bathroom. I found a vanity, 22x22, but now I am having trouble with the sink. The standard sizes are all too wide and take up to much room (there is a toilet in the way which prevents a larger vanity). I have been looking at the solid surface material and the smallest "standard" size is like 25" wide. Can I trim and inch or two from each end, and can this stuff be finished off (sanded) to look good? Thanks.
Not sure what type "ends" your countertop has. Typically, the top of "solid surface" countertops is about 1/2 inch thick... the ends usually, and the front always has a 1 - 1 1/2 inch piece attached for a finished look. I'm afraid you're going to end up with raw wood (pressboard) showing on the ends. I could be wrong - it's just what I've encountered in the past.
If you are looking at a typical cultured marble top, it can be cut essentially just like wood. However, you will be left with and unglazed edge. It can be sanded smooth, but it will not have the gloss or finish of the rest of the top.
