davidwie
12-15-2009, 08:10 AM
I have a 1/2 copper hot and cold water supply line to my shower where I want to install two shower heads. One head is a standard and the other head has 4 jets (http://www.moen.com/kingsley/chrome-moentrol-r-vertical-spa/_/R-CONSUMER:263). The jets take a 1/2 copper line.
Will I have enough water pressure for this? Any thoughts would be helpful.
Thanks,
David
jadnashua
12-15-2009, 09:38 AM
Don't confuse pressure and volume...a 1/2" shower valve can usually flow about 5-6gpm. So, what is the rating of the combined two showerheads? As you try to exceed the maximum volume, you start to lose pressure. Think a hose sitting without a nozzle, then try to decrease the flow by putting your finger over it. The supply pressure doesn't go up. In order to have the showerhead feel good, you need to be able to supply more water than it can dispense, or it's like you took your finger off the output of the hose.
davidwie
12-17-2009, 06:35 AM
Thanks for your response!
