Kohler Wellworth Model 11471
nottick
Hello and again I will say thanks in advance to any and all that can provide assistance.
Removed an American Standard bowl, back of tank was dead 12 inches from the back of tank to the center of bolts. Pipes are firm in the ground and did not move while removal took place.
Installed Kohler Wellworth Model 11471, from wall to center of bolts, have a dead 12 inches, but back of tank is 1.5 inches from wall.
Based on the pictures in the lower left hand side of this page( from Kohler, it is a PDF file), can I assume they designed this to have the tank off of the wall?
http://www.us.kohler.com/onlinecatalog/pdf/1097334_4.pdf
If this was designed to have tank off of the wall, any suggestions as to make/model which will give me a tank against the wall?
Again, thanks in advance .
Some photos , to show ...
photo will show 12 inches from bolts to wall..
photo will show the 1 1/2 inches the tank is off the wall.
You probably won't find a toilet that sits that close to the wall (or touches it). I didn't look at the spec sheet, but guess that it shows that 1.5". Most manufacturers plan for a space to account for flanges that are slightly off. Many of the Toto toilets that I've looked at are spec'ed to have 3/4" behind them with a 'perfect' flange installation (which few have).
So, you will likely have to live with at least some gap there, but it could be smaller with a different model and brand. It might even be smaller on a different one of the same type and brand...things do vary some in manufacturing them.
