View Full Version : Installing new 2nd floor bathroom - raised floor?
jharryman
12-12-2009, 10:55 AM
Hi. First off, I'm a homeowner so forgive me if this sounds crazy. I have a 2 story house and want to install a new bathroom on the second floor. I would like to do this without disturbing the 1st floor ceiling and was thinking that I could raise the floor where the new bathroom will go so that the pipes can be installed under it. I realize it is not typical but can it be done? The finished bathroom would be in the master bedroom but would require a step up to get into it. (There is enough height to accommodate this.) The toilet would sit close to the main stack in the house. The sink would be about 4' away and the shower about 8' away from the central stack. As long as there's enough height to pitch the pipes properly, this should work, shouldn't it? I've been told 1/8" for every foot is the rule of thumb.
12-12-2009, 01:47 PM
1. That pipe you intend to hook the toilet to, is the vent for the first floor so you CANNOT do it.
2. Some codes allow 1/8" for 3" drains, although just as many require 1/4", and all codes require 1/4" for the smaller drains.
3. You might have to raise the floor about 8" to accomodate the required piping, and that would create a tripping/falling hazard, plusmight DECREASE the value of you home because it would probably turn off most potential buyers.
4. You might NOT have to damage the lower level ceiling, (once you figure out how to get a new drain line to the upstairs), depending on HOW you arrange the fixtures, and how the floor is constructed.
12-12-2009, 01:54 PM
Ditto what hj said.
Especially about the trip hazards.
Removing part of a ceiling is not a big deal.
The drywall contractor I use, he makes the ceiling look better then ever, for very little money.
http://terrylove.com/images/dwv_b2.jpg
jharryman
12-13-2009, 07:26 AM
Thanks guys. AS to HJ's first caution, there is actually a bathroom already on the 2nd floor. It used to be a second apartment. our plan is to renovate this bathroom and install a second one (master suite) where the kitchen used to be. These 2 rooms share a wall. It's almost as if the 2 toilets would be placed back to back by the stack. Does that change your concern about the venting? I figured it's easier to run the water to the sink more easily than it is to run the discharge from the toilet, am I correct? The shower would be the farthest away from that main stack. As for the step up, i would make it a formal step and it would be in the master bedroom so I don't think it's particularly hazardous. I agree it may turn some buyers off, but I for one would find it unique and charming. My biggest concern is the finished ceiling height since my boyfriend and I are both tall. I could break into the ceiling below - it is where the kitchen is and there is room for a soffett- but we are trying to minimize the impact on our living space downstairs. Although, should I have a problem in the future, like a leaky pipe, maybe pipes contained under a floor are not the best plan.....?
export!
12-13-2009, 09:51 AM
Don't do something gimicky upstairs to save the very limited trouble of repairing some drywall. Especially if, as you say, there is room for a bulkhead. If you were ripping out cabinetry to modify a ceiling that would be a diffferent scenario. You can tent off the area and minimize the mess of drywall finishing. Emphasis on "minimize".
I'll let HJ comment on "unique and charming".
jimbo
12-13-2009, 10:16 AM
The access to a stack makes things a little easier. Getting slope is tricky no matter what you do. But have you considered doing the work by taking up all the subfloor on the second floor, rather than the ceiling down below. Some of both might be the least amount of work.
jharryman
12-13-2009, 10:44 AM
Yes, we would take up the subfloor upstairs, but there probably isn't enough depth to lay the pipe at the neccessary pitch per distances to/from the stack. The shower is the farthest away - about 12 feet away (maybe a little less). So that would need, what, 8" of depth? I do not think the subfloor is that deep. Plus, the joists run perpendicular to the way the pipes need to run. You'd have to put holes in the joists and that would make them weaker I've been told. So that's why I thought "raise the floor up a step". Maybe I should just bust up the kitchen ceiling. I do not have to demo any cabinets, but to get at the area where the pipes / soffett would go you'd have to stand on the kitchen counter / sink.
Thanks much for everyone's advice. It's much appreciated.
frenchie
12-13-2009, 11:10 AM
I would change my design layout for the new bathroom, before I'd build up the floor 8" like you're thinking. It's not charming or unique, it's just awkward & ugly. It suggest poor workmanship, hackery, and provokes one to wonder, what else might be screwed up about the house.
I wouldn't bore holes in 12' worth of joists, either. Again, re-think your design layout, come up with something more practical.
Remodeling, like politics, is the art of the possible.
Gary Swart
12-13-2009, 09:00 PM
Ditto what Frenchie said. A raised floor is the sign of a hack.
12-14-2009, 06:20 AM
quote; agree it may turn some buyers off, but I for one would find it unique and charming. My biggest concern is the finished ceiling height since my boyfriend and I are both tall.
I believe some people thought the Yugo automobile was "unique and charming" also, but they still got burned after buying them. Ceiling height will be a HUGE factor. Normally people want the HIGHEST ceiling possible in a master bath, NOT a lower one which could be claustrophobic to some people.
