Heat Pumps/Well Pump Problem
plantnerd
Wichita, KS
Hello
We have 2 heat pumps fed by a 1/2hp well. The "control board" for the well went out today while we were out, thus no water feeding the heat pumps. It's been around 30 deg here today.
We replaced the control board for the pump, so we now have water, but I cannot get water through the heat pumps. I know there is no water because I have a bypass to the waste line and don't get anything when the system is running. The heat pumps are fitted with Taco valves on the water out side. Any help? It's supposed to be a high of 15 deg here tomorrow, and I really don't feel like feeding a woodstove all night.
Thanks
If I understand what you are saying, you are bypassing the heat pumps and dumping the water directly to the waste line? Do you have any water going to the waste line?
Is the pump a submersible or a jet pump on a shallow well? If it is not a submersible the pump might have lost it's prime. Do you have a pressure gauge on the outlet of the pump?
