chainsawmike
The water pump on my well has started to run continuously. I turned the well power off, and removed the cover from the Square D pumptrol switch. When I lift on the rocker arm spring assembly to close the valve and open the contacts, then turn on the power, the well pump does not run. After water has been used, the pump turns on and continues to run.
Is this a clear indication of a bad switch or could it be another problem such as a leaking bladder tank or a leak in well line?
