Geberit Toilet Installation
David M
I'm considering the Gelebit pressure-assist wall mount toilet for a basement installation. I would use the horizontal discharge option.
Questions:
1) Along the wall, the optional horizontal disharge elbow and the spec shows a 45 degree angle down before going horizontal. From your experience, is this necessary? Could the supplied straight elbow be used for direct horizontal drainage along the wall; using it to the side rather than straight down?
2) Do you think a gravity swing check valve on the drainage line would be okay, if desired?
Kind regards,
David
