View Full Version : Leaking tub faucet
trobinson017
10-28-2004, 04:36 PM
Hello,
I have a 20+ yr old Gerber 3 handle tub faucet setup; hot and cold knobs and a diverter knob in the middle. The hot/cold stems were leaking so I replaced everything; both stems with new valve seats,washers, etc. and a new diverter with a new seat/washer. The stems no longer leak but now I have water dripping from the tub faucet. I crank down on the hot/cold knobs but it still drips, although slower. I took everything apart and checked all the flat washers and the tightness of the seats. All were as they should be. I even went ahead and replaced all the flat washers. I put it all back together and the faucet still drips.
What more can I do? Any ideas??
Tim
Bob's HandyGuy
10-28-2004, 07:02 PM
Does it drip only after you use the shower? There is a column of water in the shower pipe when you shut the water off. If so, then water is getting past the diverter. Open the diverter after the water is shut off and let it drain. If it still leaks, check the temperature of the water after awhile. This will help you isolate which valve might need re-doing.
