ncg45
12-03-2009, 07:01 AM
The shutoff valve for the refrigerator water line will not close completely. Water still leaks from line with the valve handle in the closed position. This is not a problem as long as the line is hooked to the fridge - but if the refrigerator is removed (like when we sell the house) we're going to have a leak.
Do you think I can just replace the valve stem (assuming I can locate the exact same valve [Jameco]), as opposed to replacing the entire valve. Or maybe put new packing in the stem? If this is not a good idea, is there a trick for removing the entire valve? I don't know if the valve body was screwed to an adapter or soldered in place(???) when the house was built.
If things really got ugly, and I couldn't remove the valve, I could access the line from the garage which is directly below.
