Please look i need expert advice quick!!!
VTXdude
New Hampshire
Please look I need expert advice quick!!!!
I'm sorry guys I'm not trying to be a whiner here but after this other plumber installed the 4 inch vent I am scared to death...
How hot should Type B pipe get??? All of a sudden after this plumber installed 4 inch pipe my Tee and chimney feed (Type B) becomes very hot to the touch! I don't recall that happening with the 3 inch pipe and in fact when I made the comment that it seemed cooler than the other pipes(when 3 inch was in) he said of course it would be because it is double lined pipe and doesn't get as hot as the single wall. Well take a look at these pics before and after it looks like he crimped the 4 inch pipe and put it OVER the Tee opening instead of in it like it was before and taped it up..to me that is forcing a lot of the exhaust out to the surface of the Tee and chimney
I don't think I am being an alarmist here am I???? Please , you guys are the experts and I need help. I'm not trying to whine but I have 2 kids in the house and am afraid of what he has done.....he also spun the Tee out a bit to get it away from the wood and now that is loose at it's connection to the chimney
Please look at before and after and help me please
I wish you guys were in NH and I know it would get done right..what is wrong with the plumbers I am getting from Sears??? They are independent plumbers/contractors for Sears
How do I find someone who can do it right? A big company????? I can't just open the phone book and guess
Please help with you expert knowledge.........I'm trying to learn
Guys it just occurred to me that it looks like he didn't use a reducer fitting and now flue gasses are going between the two walls of the Type-B vent, which is why it's getting so hot.
Am I in any danger of having a house fire with this setup? If those flue gases are going up between the walls of the pipe isn't it getting very hot on the outside of the pipe higher up behind my walls???
I can't believe this
No your not being paranoid or an "alarmist" at all. That work is HORRIBLE! any kind of tape should NEVER be used to secure flue pipe together, it should always be screwed together.
And fitting that pipe to the B-vent like that is horrifying as well. You only show a picture of that one part there I can't imagine how dangerous and horrible the rest looks. Oh did I mention what they did is dangerous?
I can't say what to do to actually make it right since I have no details and am not there in person but that is horrible and you should find someone competent enough to make that proper.
This is the kind of work that licenses are lost over after the disaster & forensic analysis. If you haven't paid for it yet, don't. Get an inspector in there to document & cite the guy, and find an alternate contractor to do it right pronto! (This would be unusually bad even for a slobby DIY job.)
Water heater vent pipe type b
If you paid sears for this work i would start with the store manager and
polity ask what kind of unlicensed hacks they have doing their work
tell him you are having the city building inspector "and" fire dept to inspect
and check your house for carbon monoxide leaks ! !
From this jackaxx installation,
you can never, never, never reduce a vent like that,
you never go from a larger vent to a smaller vent ! !
I think if sears is involved they will pay someone to correct that PDQ FAST ! !
